S60 2.5 T5 2012 Turbocharging sensor error
Hello to you. I have such a problem - with the air conditioning and free driving on, for example, in traffic jams when moving off the car, the engine's revs are quite strong. I noticed that this can happen mainly when the fan is on, but it does not have to depend on it (I'm not sure until the end). I had it so long until it displayed the check engine and after connecting the vida showed the error from the turbine boost sensor (ECM-P023624). I note that when I turn off the air conditioning, everything goes nicely, it screwed in well and there are no problems.
Errors with vida
DDM-U040100 Invalid data received from ECM/PCM A
PDM-U040100 Invalid data received from ECM/PCM A
CEM-B109B15 License plate light - general electrical failures - circuit short to battery or open
ECM-P023624 Turbocharger/Supercharger boost sensor a circuit range/performance - general signal failures - signal stuck high
Errors with vida
