Boost pressure sensor or TCV???
Old Mar 24, 2011 | 08:28 PM
Holedigger's Avatar
Default Boost pressure sensor or TCV???
2000 xc70 SE threw a check engine light today. P0236/P0237 was the code on my generic OBD II. Boost sensor circuit range/performance and boost sensor circuit low (respectively) Everything ive read says boost pressure sensor or TCV? How can i determine which it is?
Old Nov 24, 2011 | 01:33 PM
Arek's Avatar
Hi there; Newbie here..
I have the same with my 2002 S60T5.
Replaced the TCV, located by the air box..cleared the codes; went to the store came back and so did the check engine light. Is there another sensor? Or is it Something else? Like MAF or leaky turbo lines.
Old Nov 28, 2011 | 10:06 AM
Holedigger's Avatar
I replaced the Boost Pressure Sensor which is just to the left of the air box on top of the air intake pipe as it leaves the air box. It snaps in to the pipe and has one, two wire plug on it. It was around $100. No codes since then.
Old Dec 8, 2011 | 10:59 AM
Arek's Avatar
Ok. I belive this sensor is the MAP sensor; also called Boost Pressure Sensor by Volvo
Would you be able to tell me what the return voltage, from the sensor to the ECM, is; I only get 0.3V which seems to low.
The ECM voltage supply is good (5V), but I cannot find any where the return specs.
Thanks
Old Dec 9, 2011 | 02:54 PM
Holedigger's Avatar
I wish that I could help you on this one, but I do not know the answer. sorry
Monkey613268
Oct 22, 2017 10:24 PM
skamil
1998-2000 model year XC70
Feb 22, 2012 08:15 PM
endneu913
Mar 28, 2010 11:41 PM
imhereftw
Nov 15, 2009 02:56 PM
Lab_Rodent
Dec 7, 2007 06:01 PM
