S60 D5, 2004. Headlight bulb replacement
To change the bulb I removed the airbox.
Unplug sensor switch, undo jubilee clip on hose.
Airbox is held in with 3 clips that need compressing to get them to retract, used a 9mm socket with extension bar to do this. Pushed socket onto clip then pull up gently on airbox. Easy to get access to inside of headlight once airbox removed. Hope this helps.
