S60 Engine Drops to ~500RPM While Coasting/Parking Full Temp
Old Nov 4, 2017 | 02:22 PM
SuperMario811's Avatar
Default S60 Engine Drops to ~500RPM While Coasting/Parking Full Temp
Hello, all! Something strange is going on with Jody's idling. Engine drops to ~500RPM after shifting to park, or coasting for more than 1-2 seconds, but ONLY when the engine is fully warm. It started around this past April, and even stalled once; However, the issue was FAR less frequent then, and a lot of work was completed, since. If you don't know/remember, Jody is naturally aspirated (B5244S).
ALL of the following was completed AFTER this issue first occurred:
  • Complete timing belt/water pump job completed this past May
  • Spark plugs replaced less than 4K miles ago
  • New engine air filter last month
  • ETM & MAF cleaned twice within the past year (the second time being a few weeks ago)
  • ZERO OBDII/VIDA DICE faults/codes
  • PCV system is in excellent working order
  • New alternator, and voltage regulator
  • New serpentine belt
  • There's really nothing else I can think of besides one occasionally squealing brake rotor
A video of the intermittent idling issue here:
A video of my Magneti Marelli ETM being tested here:
Attached photo of the ETM, as well.
Also, Jody hit the 248K mile mark recently!
Anyways, suggestions? Thanks in advance!
Magneti Marelli ETM (2001 S60 NA)
Old Jan 15, 2018 | 07:25 PM
Exclamation Check/Replace Your Fuel Injector O-Rings
Since there were no answers, I have done weeks of research, and found out a couple of things, in case you happen to stumble upon this thread while searching for a more definitive answer:
Many times, it may not be your ETM, MAF, or alternator, and my particular S60 2.4 NA does not have an IAC, as far as I know, but the problem could very well be the fuel injector o-rings due to aging. This also applies to many non-Volvo cars.
if you are uncertain about when your fuel injector o-rings were last replaced, be sure to have them checked, and replaced, if necessary. It can cause more serious issues later on. A video was posted showing the procedure with a P2 S60 (PCV Servicing).
Also, check your PCV valve, as well. This can be checked at least two different ways according to the second video.
Trisha Toots N Kingston
Dec 27, 2014 03:49 PM
Bribo
Mar 3, 2014 09:28 PM
brizzle1
Oct 2, 2013 08:38 PM
act1292
Nov 11, 2009 10:24 AM
lhfgracebanet
Apr 19, 2009 05:37 PM
