S60 Error Codes, Definition, Solution
Old Mar 15, 2013 | 05:50 PM
GaryDG's Avatar
Default S60 Error Codes, Definition, Solution
Hi
Does anyone have a comprehensive list of error codes and the associated meaning and solution?
Like what's shown below which I pulled off this forum from a couple posts
Error Message:...Bulb Failure Position Light
Meaning1:.........Tail light missing
Solution1:..........Insert,reinsert good tail light
Meaning2:..........Message is error
Solution2:......... Slam trunk, it may go away
Error Message:... Check Brake Lights
Meanining:..........Various
Solution:.............Refer to
https://volvoforums.com/forum/volvo-...failure-46641/
Old Mar 15, 2013 | 08:06 PM
ES6T's Avatar
Error codes or error messages?
Error messages like that are explained in the owner's manual.
Old Mar 15, 2013 | 08:55 PM
GaryDG's Avatar
Thanks ES6T
The owners manual is extremely superficial and note of these MESSAGES are shown in mine(I'll show a pic shortly). The owner's manual seems to be written for people who can change a light bulb, but that's about it.
Moreover, none of the messages in the user manual come close to the thought and dialog that is found here on some messages.
So is there or can we pull together that complete list?
Gary
Old Mar 15, 2013 | 09:08 PM
ES6T's Avatar
The problem is some of them have many possibilities. While "Bulb Failure Position Light" can only refer to one of four taillight bulbs, "Engine System Service Required" could be many things. The fault codes stored in the car would need to be read for things like that.
Old Mar 16, 2013 | 10:34 AM
GaryDG's Avatar
The messages I refer to are the error messages that appear on the left side of the dashboard. It is those messages I originally asked about, and yes, for those messages there may be one or many reasons for that message - and it the list of those messages, probable cause and potential solution that I am looking for.
Yes, the Check Engine Light (message), right side of dashboard, is retrivable by use of an OBDC reader. In this case, it is OBDC2. I have an AutoEnginuity device that allows me to read those standard codes for this car. AutoEnginuity does not have the "add on" for Volvo's, so detail codes like oxygen sensor readings, timing, specific vacuum leaks, cylinder and valve status aren't available.
So, ES6T, looks like you've posted here for awhile. Have you not seen such a list?
Old Mar 16, 2013 | 10:59 AM
ES6T's Avatar
I haven't been here that long and haven't seen such a list, sorry.
There are other messages that need a scanner, like Engine System Service Required or Transmission System Service Required.
yuuu
Apr 26, 2014 10:09 AM
twistab4pudd
Jan 5, 2011 08:53 PM
98v70ct
May 29, 2010 04:52 PM
dcarlson12
Nov 3, 2008 01:52 PM
tomservo
Feb 16, 2006 01:28 AM
