s60 not starting (ECM)
Old Feb 19, 2013 | 02:19 PM
s60t's Avatar
Default s60 not starting (ECM)
hi all
I have a 2002 s60 turbo , 3 weeks back I was driving the and suddenly the car started shaking and I noticed the RPM meter not moving , I stoped the car and tried to run it again but no use , I took it to a garage with and tried to check the car for codes , the ECM Returned Signal missing , any how he checked their is power in all the car but the injectors , each injector have 2 wires , 1 with direct power and the other one gets power while cranking ( from the ECM ) , I tried to bye a used ECM + KEY + Immobilizer , now when cheking for codes , we can see the ECM but still no power to the injectors , do I need to get the CEM also or this wont help ? any body knows what I can do ? I am waiting 2 or 3 days If no use I will sell the car as scrap , please help
Old Feb 19, 2013 | 09:42 PM
ES6T's Avatar
Take it to a shop that knows what they are doing, as this one clearly does not. ECMs are not a common failure at all. The injectors do not get power from two wires. The immobilizer is not it's own separate unit. A used ECM won't work without programming and may not work at all. You can't just replace a key with a used one witout replacing the column lock.
Old Feb 19, 2013 | 10:05 PM
s60t's Avatar
this is the best garage in this part of the world , and what I wrote in my post is just what I understood from them , I heard about Xemodex in canda , they want the old ECM + the used one I got tand they will reprogram for me for a cost of 299$ + 280$ Freight Charges
Old Feb 19, 2013 | 11:25 PM
s60t's Avatar
and also maybe i am putting it wrong , they used like a xmas lamp to see if their is power in the injectoer plug while cranking , the lamp didnt light at all while cranking , only if he remove one leg of the lamp and touch any part of the engine their is light
Old Feb 20, 2013 | 08:05 AM
ES6T's Avatar
Okay, so the ECM is not grounding the injectors. It could be the ECM but you'll need to send it to xemodex to try to repair. Just plugging another in won't work.
Old Feb 20, 2013 | 08:50 AM
s60t's Avatar
just now i changed every thing ( ECM + CEM + Key Antena ) and the injectoers are getting power while cranking but still not starting and and 2 msg their , Reduced engine performance and anti-skid service requierd , i think if i could remove the errors the car may start
Old Feb 22, 2013 | 10:54 AM
s60t's Avatar
the car finally started but still starting hardly , the plugs are flooded with fuel and not getting ignition , any ideas
JDaman
Jan 13, 2024 06:18 AM
s60-owner
Jun 17, 2015 06:38 AM
dejan_da_dude
Feb 24, 2015 01:17 AM
jofu789
Feb 22, 2007 07:19 PM
