S60 oil recommendations
Old Oct 21, 2010 | 05:17 AM
twade's Avatar
Default S60 oil recommendations
Hi my name is Tim. Thanks for the replys in advance. I have a 2003 S60 with 143000. I just bought the car. What type of engine oil should i use.
Any recommendations where to get repair manuals.
Old Oct 21, 2010 | 08:37 AM
jks2's Avatar
Welcome to the forum. I use Quaker State Full Synthetic in my cars. Most around here will recommend synthetic, just the names will change (Mobil 1, Castrol, Pennzoil, etc.)
Old Oct 21, 2010 | 09:21 AM
VolvoS40S60's Avatar
I have a 2001 S60 non turbo & I bought it when it had 97,000 miles in april 2007.. It now has 105,000 miles. It was using regular oil when I bought it & I still use regular oil. the only difference is that I use Castro GTX 5w30 during the fall & winter months & 10w30 during the spring & summer. I also change my oil myself before 3000 mile intervals. I use Mobil1 on my S40 because it is a turbo & alternate between 5w30 & 10w30 as the temperature changes. If yours is a turbo its better with synthetic but I guess it's your decision because of the high mileage of your car. Take note that many people have complained that they start to use special "High Mileage" oil in their cars then noticed their gaskets started to leak. What did the previous owner use? Do you see sludge buildup? If the previous owner used dino oil & you see sludge, & want to switch to synthetic, try using Penziol High Mileage. Many people claim it does a good job as far as removing sludge. Use Penzoil for a while then when the sludge situation has gotten better, switch to synthetic. Bottom line is it's your call & synthitic gives the best protection. good luck
earlfleetwood
Aug 23, 2014 09:36 PM
Joel Burgess
May 22, 2013 03:45 PM
daveyleeprinsze
Apr 13, 2012 08:26 AM
dlaxdal
Apr 4, 2009 12:10 AM
rich213
Oct 28, 2005 04:32 AM
