Oil recommendations?
Old May 21, 2013 | 12:00 PM
Joel Burgess's Avatar
Default Oil recommendations?
Hey, all.
I've got a 1992 940 GLE with 263,510 miles.
It's not due for an oil change yet, but I need to put about half a quart in it.
It's hot now, so I was wondering if I should go for a thicker oil.
Any recommendations? Also, any benefits to synthetic?
Old May 21, 2013 | 12:53 PM
10W30 unless you live in the mojave desert and its summer, then use 15w40, or you live in the colorado rockies or northern vermont and its the depths of sub-zero winter, when you might want to use 5w30
I use synthetic (mobil 1) on turbos, I think its overkill on a non-turbo. any quality major brand should be fine.
Old May 22, 2013 | 03:45 PM
lev's Avatar
lev
I doubt you have a GLE which is designation for the 16 valve motor in the 90's B234F motor which was not available in 1992. You most likely have a GL with a B230F? You don't need any special oil if your engine is in a good nick... 10w30 is fine.
earlfleetwood
Aug 23, 2014 09:36 PM
daveyleeprinsze
Apr 13, 2012 08:26 AM
twade
Oct 21, 2010 09:21 AM
dlaxdal
Apr 4, 2009 12:10 AM
rich213
Oct 28, 2005 04:32 AM
