S60 R Xenon headlight assembly needed
Old Sep 27, 2010 | 08:39 PM
1995Turbo's Avatar
Default S60 R Xenon headlight assembly needed
Does anyone know where I can get a driver side Xenon headlight assembly for a 2004 S60R. Mine is getting wet inside and blowing a fuse every time a headlight is plugged in, garage said I need a new assembly and the dealers want over a thousand for one. Cheapeast I found so far is $850 which is still outrageous. A good used one for 400 or 500 would work for me at this point.
Old Sep 27, 2010 | 09:45 PM
nmikmik's Avatar
ah, junk yard I'd guess, but why not try find the source of the leak? May save you a couple'a bucks
Old Sep 28, 2010 | 09:16 PM
1995Turbo's Avatar
Mechanic told me he thinks the whole assembly is bad, keeps blowing a fuse every time a bulb is plugged in and it goes to initialize when turning on.
Old Sep 28, 2010 | 09:20 PM
Maybe the ballast is bad.
Old Sep 29, 2010 | 08:57 AM
nmikmik's Avatar
So what your mechanic is saying is that we finally graduated to $850 throw away items? I'd look for another mechanic or try figuring out yourself what could be wrong with it, after all it's just wiring and some components that if not easily still can me replaced.
Here is approximate list of components (not sure if it fits your particular install) try calling these guys or anyone else willing to spend a minute helping you.
good luck
woodrows80
Apr 27, 2015 11:01 AM
ureiman
Apr 14, 2015 07:43 PM
Dyna Rider
2001-2013 model year V70
Nov 5, 2012 12:28 PM
electric blue
Mar 19, 2011 08:40 AM
wilrobbinsct
Dec 7, 2010 03:39 PM
