S60 radiator leak
Had to go look at my car really quick. It looks like it would be easily accomplished. I didn't see any real need for any special tools Looks like you pull the front sill off disconnect the hoses and tranny cooling lines, remove the fan assembly, move wires out of the way, and then pull it up and out. I've heard it's easier to take them out through the bottom, but I think you would have to have the car up pretty high.
Thanks for the come back. There appears to be a trans cooling line on the upper rt side of radiator when your facing it from the front of car. It doesnt have any threads that I can see and it has a plastice eared piece that seem to float. This has all wheel drive. Could that be the difference? If so where can I get the tool to remove it? DAN
