S60 Type of Coolant
I know this will probably bore some people, but I would like to double check the type of coolant to add to the surge tank in an S60. I could not find anything on it in my manual. The owners manual on my 01 says to go see the dealer. It also says you "shouldn't need to change the coolant", which implies it is some kind of super special stuff. The remaining coolant in the tank indeed looks green, like regular Prestone. Can I add Prestone?
I have heard a lot of warnings concerning mixing coolants (I have two cars now with coolant issues). Maybe for a flush and fill Prestone would be good. As for mixing, Volvo says:
Radiators from the field have been analyzed at Volvo's internal laboratories. The analysis indicated corrosion in the internal gearbox fluid cooler. This early failure may have occurred if the coolant was not of the correct mixture ratio (ie. 50% glycol, 50% water), which is the optimal ratio for the cooling system. This mixture ratio must be followed strictly to meet all requirements of the cooling system in order to optimize the freezing point, corrosion durability, boiling point and lubrication. When filling and topping up, use only Volvo ready-mixed coolant. Volvo's guarantee does not apply if the coolant is contaminated with other mixtures or non-genuine coolant of incompatible properties is used in your Volvo car.
(ref: http://www.volvocars.com/sg/salesandservices/maintenance/volvoserviceoffers/Pages/VolvoCoolant.aspx)
jollygoodgold
07-16-2007 12:06 PM
