S60 VOLVO 2005 It does not turn on
Old May 10, 2019 | 08:28 AM
Taltor MX's Avatar
Question S60 VOLVO 2005 It does not turn on
Good afternoon friends
I would like to know if someone happened to him something similar my volvo s60 2005 no turbo had gone out of time and sent him to fix valves all right up there but apparently he ran out of battery and when they put it together again they had to load again the then tried to turn it on but no current goes to the gear and check the gear separately and if it works but the normal circuit of the car does not give full gear they bridged the march and already to give key the march towards its function but it did not light as if The spark plugs or the combustion system could not signal, they passed a scanner and it only marks a problem in the transmission.
I would like to know if someone happened the same thing or if they can give me a clue as to what it might be since in my city they do not have to check the volvo computers
Thank you very much in advance
Old May 10, 2019 | 10:52 AM
what happens when you turn on the key? any immobilizer warning lights? Does the dash light up? When you turn to start, do you hear any clicks and does the engine crank over? Did you try a jump start?
Note, if the key fob is working, locking/unlocking the doors 5x will reset the immobilizer so that's easy enough to try before trying to start.
Old May 11, 2019 | 12:11 AM
Taltor MX's Avatar
aware I will try with the key control to have the board turn on normal turn back with comments
Old May 22, 2019 | 10:35 AM
Taltor MX's Avatar
Question
hello everyone again
follow the problem of my volvo, if there is no bridge in the march of the march it does not work basically does not do anything
video attachment of what it does
in a YouTube video they mentioned a similar problem and it was related to the .CEM module. so I started to check it and it had a fuse of 20 melt replace it and follow the same problem still
What could be the problem?
Gustav
Nov 11, 2017 01:01 PM
Virgobaby
Feb 15, 2015 07:59 PM
bengals25lucas
Mar 5, 2014 01:37 AM
Cambridge Volvo
Feb 1, 2010 12:29 PM
