S60T5 right axle replacement problems...
Good afternoon to every passionates...
I know somebody explained this procedure but I started this work on my driveway ,i am stuck and the snow is coming....
1) How do you exactly separate the lower ball joint (I unscrewed the big bottom nut and tryed to lift the strut and disk out of the ball joint...but not evident indeed !!). So a very described procedure would be very appreciated. I have already taken the brake caliper out of the way,taken off the roll bar joint,and the central wheel nut....
Also, after I will be able to separate the ball joint,do you have to just pull the driveshaft out ot the gearbox after having taken the 2 bolts off from the bearing holder or are there more tricks to know.....
Thanks in advance to help me....
dbarstow
08-01-2010 02:06 PM
