service required
Old Aug 27, 2011 | 04:54 AM
v1lcins's Avatar
Default service required
Hello everyone! I have s60 2.4 d5 2002! Got it couple weeks ago , with one issue , there was a leak on top of radiator, it wasn't bad one, so I tought it be ok. Then discovered lots of black smoke!! Ok that's might be intercooler!! Volvo service confirmed that. So yesterday I changed that( old one was leaking air like sponge!) but now There's even bigger fault( I've done something wrong - maybe) service light came up engine service required! And it doesn't rev more than 3000 rpm! In one moment when I started the car it was ok ( just wierd nose came from front like air is squealing in somewere, but just when you rev it). I will try to read the code today at service! But maybe anyone know what might be the problem! Some connection or injector!!! What can be gone wrog if I just changed the intercooler!!
Old Aug 27, 2011 | 05:06 PM
MYS6T's Avatar
I would start at the couplers at the intercooler to the Turbo. The connection at the throttle body and the turbo couplers. These would cause the Cel and make the car fall in to limp mode.. Make sure the clamps are tight.
Old Sep 6, 2011 | 11:45 AM
v1lcins's Avatar
solved! intercooler sensor wasnt working- replaced- and everything is fine!!
giannis-21
Aug 10, 2011 01:50 PM
chrissygm
Sep 30, 2008 05:53 PM
Gonzo
Jul 25, 2006 03:56 PM
digsetcrush
Sep 10, 2004 06:52 PM
