Speedometer question
Old Feb 27, 2011 | 09:39 PM
Cobranut's Avatar
Question Speedometer question
A friend has a 2005 S60 turbo with automatic.
He needs to recalibrate the speedo.
I can get an inline recalibrator but I need to know if this car uses a speed sender on the transmission to drive the speedo or does it use a signal from the ABS system?
Thanks,
David
Old Feb 27, 2011 | 09:43 PM
I believe the main signal for the speedo is from the ABS.
Old Feb 27, 2011 | 09:55 PM
Cobranut's Avatar
Default Signal wire.
Does anyone know if the speed signal is available and where to access it in the harness, wire color, connector pin #, etc?
Thanks,
David
Old Mar 7, 2011 | 08:31 PM
Cobranut's Avatar
Question
Anyone???
Thanks,
David
Old Mar 8, 2011 | 07:00 PM
I will see if I can find time to search the wiring diagram.
Old Mar 9, 2011 | 08:03 PM
Cobranut's Avatar
Thanks, I appreciate that.
[QUOTE=tech;260161]I will see if I can find time to search the wiring diagram.[/QUOTE/
urdrwho
Oct 31, 2013 04:18 PM
s10lowrider1994
Sep 11, 2011 07:53 PM
alexi3rdgen
Jun 13, 2008 07:22 PM
olegs70glt
Jul 11, 2007 11:35 PM
paulbelanger
Oct 28, 2005 09:37 PM
