SRS Code 00D0...seatbelt buckle or the pillar mounted unit?
Old Dec 31, 2013 | 03:51 PM
Tubotato's Avatar
Default SRS Code 00D0...seatbelt buckle or the pillar mounted unit?
Hi...I made the mistake or removing the drivers seat to try to tighten some play in the seat track without removing the negative battery lead...which gave me an SRS Urgent Error code. There were two codes in the SRS...one I could clear, and code 00D0 (driver's side seat belt) which will not clear. I swapped the seat belt buckle on the floor and the problem won't go away. The old seat belt looked fine and the wire wasn't damaged. I also sent out my SRS module to myairbags.com to get it checked and reset...they returned it saying it was reset but the error is still there. Is there any electrical connections in the driver's front shoulder belt? Hate to keep swapping parts but I hate taking it to the dealership even more...swapping parts is unfortunately still cheaper! Any help would be appreciated. Thanks.
2001 S60
Old Dec 31, 2013 | 03:52 PM
Tubotato's Avatar
Adding insult to injury...the driver's seat track is still loose! Any help with what typically loosens/wears out would also be appreciated.
joiseystud
Sep 27, 2016 06:33 AM
RobJamesInSheffield
2001-2013 model year V70
Apr 26, 2015 03:03 PM
volvoQ's
Oct 31, 2010 07:46 PM
jbnery6465
May 5, 2009 05:47 PM
Lichty17
Aug 4, 2005 04:24 AM
