Stalling S 60
Hi, I'm new to the forum. I have an 02 S 60 and recently the vehicle started stalling when I left off the gas and was coasting. I have also noticed for some time that when I brake the RPM goes down to 500 and then just before I completely stop, it kicks back up to about 800. The car would also periodically stall while moving with the brake applied. I am assuming there is a sensor tellin gthe car to do this.
Any guideance is greatly appeciated. Thanks!
Had the same probelm with my 04' S60. I went to the dealer and a software update fixed it. The problem is cased by buildup in the thottle body causing restricted air flow. The software update tells the thottle body to open a little further at idle.
But, since you have an 02' you maybe interested it this: http://etmsettlementdocuments.com/
My '04 did the same thing. I know your car is a '02, but this might help you.
IMPORTANT RECALL NOTICE
May 25, 2007
To all Volvo Retailers and Employees:
RE: Recall 181, certain model year(s) 2003-2004 S60/V70 Fuel Pressure Sensors
Volvo Cars of North America, LLC (Volvo) has notified the National Highway Traffic Safety
Administration and Transport Canada that we will perform a Voluntary Safety Recall to replace
the Fuel Pressure Sensor on certain model year 2003 and 2004 Volvo S60/V70 vehicles.
The fuel pressure sensor (FPS) located on the left side of the fuel rail, may at times transmit
incorrect signals regarding the fuel pressure to the Engine Control Module (ECM). If the signal is
outside of the pre-programmed allowable limits, a Diagnostic Trouble Code (DTC) may be set
and the Check Engine Light (CEL) will come on.
Engine misfire may occur during driving that in turn can reduce the engine torque, in the worst
case scenario the engine may stall without warning.
GOVERNMENT NOTIFICATION:
As required, Volvo has notified the United States Government that it is preparing to launch
Recall 181.
CUSTOMER INQUIRIES:
As you know, the current state of media and Internet technology can bring immediate attention
and public awareness of Recalls. We are sending you this information before formally launching
this Recall so that you will be prepared for customer inquiries. If you are unable to answer a
customer's inquiry direct them to: Volvo Customer Care 800-458-1552
RECALL DESCRIPTION:
• 2003 and 2004 Volvo S60 and V70 vehicles with the following engines (codes):
o B5244S (61), B5244S6 (64), B5254T4 (52) B5254T2 (59)
CORRECTIVE ACTION:
Vehicle owners will receive a letter via first class mail and will be advised to contact their retailer
for an appointment. The Fuel Pressure Sensor will be replaced at no charge to the customer.
If you have any questions concerning this information, please contact me at 201-768-7300
extension 7908 (akopstei@volvocars.com)
Regards,
Adam Kopstein
Manager, Automotive Safety & Compliance
May 25, 2007
Recall 181.
CUSTOMER INQUIRIES:
RECALL DESCRIPTION:
CORRECTIVE ACTION:
Regards,
Adam Kopstein
