stalling,scnnect battery,codes
stalling,disconnect battery,codes
Had this 2004 Volvo s60t since September of last year. I was told about the stalling issue but I traded for the car anyway as I wanted to try my first Volvo.car is amazing. just trying to fix the issues
like most with this car,it would just die goig down the road,i got used to laoding up the throttle and it ould come back but sometimes it would die.pull over,wait a few turns on the key and she would fire back up. we started using the 93 octane instead of the 87 and she ran better,didnt stall as much but the cat began to stink.car has a crap load of codes...cat...o2 sensor..fuel this n that...etc etc. doubt it means it is all bad,just one issue might be triggering it all.
anyway..recently,car has began to run like crap..stalls a lot and takes 15-20 minutes to fire back up. it was about 80 degrees when I got it,it is now close to 100 daily.
last few times,i disconnected the battery ground,waited 1 minute,hooked it back up and she would start again.
so,am I havn ecu issues or should I be lookn at o2 sensor/cat issue? maybe the fuel pressure issue?
thanks
thanks
youanimal55
01-19-2009 01:23 PM
