00 S40 stalling at low RPM's, numerous dash lights...all reset w no codes
Old Jan 19, 2009 | 01:23 PM
youanimal55's Avatar
Default 00 S40 stalling at low RPM's, numerous dash lights...all reset w no codes
infrequently the radio codewill have to be reset after stalling. Lastest advice is to replace ignition switch, battery is fairly new, cables and positive feed check out, new alternator. Also, have been advised that the ECM may need replacing. had dealership reset codes, ECM-25, and flash the computer.Recently, had codes for mass flow sensor and throttle position sensor. Called a tech at Auto Scandia in Herdon Virginia describing problem that's existed for two years and he didn't hesitate when hearing radio code has to be reset ocassionally... replace ignition switch
98T5
May 19, 2021 02:44 AM
karatechop22
Mar 20, 2012 03:52 PM
voyager1
Oct 26, 2011 04:27 PM
99S80DFW
Apr 26, 2009 08:05 PM
clintw
Jan 22, 2008 08:05 AM
