Towing with a S60 AWD
Old Dec 17, 2005 | 12:52 PM
CDNSVTGuy's Avatar
Default Towing with a S60 AWD
I am thinking of purchasing a 2002 or 2003 S60 2.4T AWD.
I own a seadoo boat with a tow wieght of 1,800lbs.
Volvo claims towing capacity of the S60 is 3,300lbs.
I'm wondering about the turbo? Is towing with a turbo good practise?
Also, anyone out there have a hitch installed on their S60? Does the install look Ok?
Some cars just aren't meant for having hitches on them.
Never thought I would be looking at purchasing a car again, thought I would be heading in the SUV direction but I am impressed with Volvo (my dad just bought his second XC70).
Any advice would be great.
Regards,
Old Dec 17, 2005 | 08:02 PM
Black Beauty T4's Avatar
Default RE: Towing with a S60 AWD
Hi CDNSVTGuy.
For that sort of weight you'll obviously need a braked trailer - does your estimated tow weight include the trailer?
Usual considerations such as quality & rating of the tyres and increasing tyre pressures will apply.
AWD will assist with traction & handling. Brakes will need to be in tip-top condition & if it's unclear whether the brake fluid has been changed in the past 2 years it would be best to change it & upgrade from DOT4 to DOT5.1 (handles increased brake temperatures better & is more suited to heavy duty/high performance motoring).
Turbo should be absolutely fine, so long as you:-
A) Use a suitable high quality fully synthetic engine oil & quality filter - standard Volvo filter is good.
B) Change the engine oil & filter more regularly than you would for standard motoring conditions/use.
C) Always allow the engine to tick-over for at least 3 minutes before switching the ignition off, to allow coolant flow to cool it - the turbo spins at incredibly high rpm and if you simply switch off the ignition immediately, the water pump halts & circulation of coolant stops, so heat is not carried away from the turbo, so it overheats and deterioration occurs.
D) Keep the cooling system in good condition e.g. check condition & tension of water pump drivebelt, ensure that the coolant has been changed within the past 2 years, keep radiator free from clogging leaves, insects, trash etc., cure any hose/radiator/pump leaks, ensure coolant level is correct.....
Finally, the transmission will be under a lot of strain, so a transmission flush & refill with fully synthetic fluid of correct grade is strongly recommended - ensure that rear differential on AWD system gets new fluid.
Hope this helps.
BB
[sm=icon_cheers.gif]
Old Dec 18, 2005 | 11:15 AM
CDNSVTGuy's Avatar
Thanks for the advice on the fluids. I will certainly have them looked into, if I buy the vehicle.
Yes, the tow weight of 1,800lbs includes the trailer. It doesn't require a brake assisted trailer.
Called the dealership, ouch, the hitch assembley and harness for the S60 isn't cheap..........at least through Volvo.
Old Dec 18, 2005 | 05:44 PM
I'm not surprised that the cost of the towbar assembly from Volvo is high, but quality of parts & fitting should be high too. No doubt an independent specialist can supply & fit cheaper.
Clearly there are different towing regs in U.S.A. - in Europe, towing more than 1,650 lbs unbraked is considered dangerous & is illegal, see:-
http://www.volvoclub.org.uk/towing.shtml
Amongst other things, it reminds us:-
"Towing limits
The maximum gross (fully laden) weight of an unbraked trailer is 750kg, or half the kerb weight of the vehicle - whichever is less. The gross weight of a braked trailer should generally not exceed 85% of the tow car's kerb weight. Refer to your tow car manufacturer's manual for the kerb weight."
As I say, this refers to European regs only, but does otherwise give sound advice.
Regards.
BB
[sm=signs003.gif]
strummergrrl
Nov 11, 2018 02:33 AM
Quack
Jul 16, 2013 11:25 PM
sklater
Apr 18, 2010 04:26 PM
Genna
Mar 9, 2009 09:04 PM
manny 1
Mar 5, 2009 01:39 PM
