Tranny Fluid in Coolant / Radiator Change
Old Feb 16, 2007 | 12:12 AM
phxvolvo's Avatar
Default Tranny Fluid in Coolant / Radiator Change
OK I'm officially ready to scream. [:@][:@][:@]I found out today that the POS radiator has developed a hole in it allowing the coolant and tranny fluids to mix...yep a whole 69k on the car, sick! So the dealer wants to not only change the radiator but the tranny as well (LMAO) it's slipping slightly but mostly because it's low on fluid. Well after hearing they want $1000 to pull the radiator I want to look into pulling it myself. So I need a little help since there are no FSM's for this thing.
1. how long should it take keeping in mind I've pulled engines and trannies.
2. Is there a trick to separate the AC condenser from the radiator without having to discharge the AC system.
3. can you flush the tranny using the transmission cooling lines?
4. are there any other tricks to get the radiator out?
5. can the radiator be serviced?
6. is there any negative aspects to installing a separate tranny cooler and abandoning the one in the radiator?
this whole thing is blowing my mind when I'm comparing it to my Land Cruiser that has 200,000 miles on it and has never had a major repair more than an alternator.
2003 s60 2.5t automatic FWD
phoenix, az
Old Feb 16, 2007 | 02:55 AM
akirk6884's Avatar
Default RE: Tranny Fluid in Coolant / Radiator Change
I would say just replace the radiator and do a tranny flush...if the tranny doesn't slip after this then your probably fine. I believe my 97 850 GLT had this similar hole in it and well it wasn't slipping, but then again it had 150k on it. The Land Cruiser is a $65000 ride... have you ever done any kind of coolant flush on the Volvo? I would say it's safe to do it at least once a year.
Old Feb 17, 2007 | 02:16 AM
The job will take you some time to do it.
Leave the condenser in the car and drop only the raditor.
It is not common on these cars for it to happen.
Try flushing the tranny from the cooler lines.
Old Feb 20, 2007 | 11:30 PM
phxvolvo's Avatar
"drop", is that how it comes out, from the bottom?
Old Feb 21, 2007 | 09:10 PM
Yes it comes out the bottom.
Old Feb 21, 2007 | 09:31 PM
Fisher's Avatar
How did you first notice the tranny oil in the coolant system? Did you notice the tranny shifting poorly first? Just trying to be on the lookout. TIA. Vadis actuallyhas a procedure fortranny fluidchange through the cooler lines so yes it can be done.
Old Feb 21, 2007 | 10:31 PM
phxvolvo's Avatar
Any other hints / things to avoid?
You don't happen to have the factory service pages with this?
Old Feb 21, 2007 | 10:33 PM
phxvolvo's Avatar
Coolant temp was a little high and noticed slightly rough shifting. Thought tranny fluid was low.
Old Feb 21, 2007 | 10:45 PM
Sorry no pages.
If you want a pretty good walk through try to get Vadis off of E-bay.
It is what the Dealer used to use.
Old Feb 24, 2007 | 10:50 AM
Fisher's Avatar
So, is the tranny fluid low? or is there water in there? If the tranny fluid seeps into the coolant, I guess that is better than in the other direction. Replacing a radiator is a lot easier and cheaper than a tranny. PM me with your address forthe Vadis writeup. As all of Vadis, its pretty basic.
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
960wagongreen
Jan 16, 2012 09:36 PM
BamaGetaway
Nov 8, 2010 10:19 AM
Rustynuts
Feb 24, 2007 10:59 AM
volvoforums53
Jul 16, 2006 12:02 PM
