Turbo SOund
Old Nov 24, 2008 | 08:24 PM
SeanSinger11's Avatar
Default Turbo SOund
the turbo sound SICK when the airbox is out. is there anyway i can make it always sound like that? would a drop in K&N filter help the sound at all?
Old Nov 24, 2008 | 09:31 PM
S60 R's Avatar
Default RE: Turbo SOund
You mean the air filter was out, or the airbox was off? At least on the R the stock air box is quite restrictive. Maybe something like this, got to post #33...
http://www.s60r.com/forums/index.php?showtopic=2884
Old Nov 24, 2008 | 11:35 PM
TIPSP's Avatar
Got Boost?
If you put a cone filter on then you will hear it all the time.
You might hear it with a K&N panel filter.
Old Nov 25, 2008 | 09:03 AM
ya no i just took the top of the airbox off of the whole box, the filter stayed in but the hose wasnt sucking from the filter, it was just wide open. it was really loud and i liked it, so yes to a K&N?
Old Nov 25, 2008 | 10:08 AM
TIPSP's Avatar
Got Boost?
You might hear it with the drop filter. I have never tried one, I do have a cone filter and I hear it.
Old Nov 25, 2008 | 11:48 AM
S60 R's Avatar
Personally I don't use any oiled filter. If you over oil it it can mess with the MAF sensor.
Old Nov 25, 2008 | 08:43 PM
S60b00sting's Avatar
with the complete air box closed with a k and n panel filter in u cannot hear the whoosh from the cbv releasing pressure, with windows open and no ac/heater or radio on u can hardly hear the spool of the turbo...if u like the sound remove the box leave the front dampers to bring some cooler fresh air from the grille in that area and box off the bottom and 2 sides nearest the engine and run a cone filter
Old Nov 25, 2008 | 10:43 PM
TIPSP's Avatar
Got Boost?
and build a custom heat shield...nothing too fancey.
A peice of doulbe-walled cardboard, cut it to the shape you want and use some Rust-oleum high-heat BBQ black and some rubber as a seal.
Or get a small plastic bucket or trash can and put the filter in there, and paint it.
Here is what I did to my dad's car:
Old Nov 26, 2008 | 10:06 AM
derekkoop's Avatar
I went on Eurosporttuning.com and bought the setup with cone and heatshield and other parts needed, it was only like 125 bucks or something, easily installed. The sound is awesome, it definately makes the car sound more beefy as well. I definately recomend the one I bought. Good luck!!
Old Nov 26, 2008 | 01:12 PM
TIPSP's Avatar
Got Boost?
Only $125...not bad.
Mine was FREE.
Not raining on the parade or anything.
Old Nov 26, 2008 | 01:33 PM
checked that site, and i could only find ones for 199+ lol, are there any kinds of just cone air filters that work? without the full system?
here is the sound of my turbo with the air box taken out if you guys would like to hear
http://vids.myspace.com/index.cfm?fu...deoID=47103504
Old Nov 26, 2008 | 01:51 PM
TIPSP's Avatar
Got Boost?
Go to autozone and pick up a K&N cone filter ($30-$60) or a Spectre cone filter ($25).
I have a spectre cone filterand it works very good.
Old Nov 27, 2008 | 12:13 AM
derekkoop's Avatar
were the parts given to you? cause the stuff you put on had to have cost something, right?
Old Nov 27, 2008 | 12:31 AM
will the spectre cone filter mess with the MAF?
Old Nov 27, 2008 | 12:41 AM
And also, will it fit?
Old Nov 27, 2008 | 12:50 AM
TIPSP's Avatar
Got Boost?
ORIGINAL: derekkoop
Don't give away my secret!!!!
My dadscar in the picture came with the filter, so all thatwas added was the heat shield, which was made out of left-over material from my CAI. The one on my car cost me ~$50.
ORIGINAL: SeanSinger11
The filter will not mess up the MAF. No filter should mess it up. If the owner over oils it...then yes it will.
I don't remember the OD of the MAF's. You will have to measure the outer diameter of the MAF where the hose connects.
The filters from spectre come with a 3in insert all the way to a 4in insert. K&N has cone filters withs ID's of 2in all the way to 7in. so you will have to find one that fits.
Edit: the sound in the video is the stock CBV which is the same as a BOV. Yes it sounds awsome.
And if oil scares you ....AEM sells oil free cone filters
Old Nov 27, 2008 | 10:24 AM
  #17
AzNick's Avatar
ORIGINAL: derekkoop
Yes, but as far as performance, what do you get?
Thanks
Old Nov 27, 2008 | 10:34 AM
  #18
TIPSP's Avatar
Got Boost?
ORIGINAL: AzNick
Thanks
Well as far as preformance...
Not much...Maybe 2-8hp, and I think the EST intake still lets in some engine heat though.
This is most useful when paired up with an exhaust system and an ECU upgrade.
Old Nov 28, 2008 | 01:18 AM
  #19
derekkoop's Avatar
I would say that I noticed the throttle response more then anything... is it gonna be a huge difference in 0-60 probably not, but before I had it, there was a split second when you step on the gas, and when the car actually goes, and now it's like step on the gas and go... I recomend it, and it was an easy install. took about fifteen minutes.
Old Nov 28, 2008 | 01:27 AM
  #20
TIPSP's Avatar
Got Boost?
ORIGINAL: derekkoop
+1
Plus the EST probably looks nicer than mine anyways.
80sGuy
Nov 12, 2014 02:44 PM
hordur
Aug 20, 2008 12:06 AM
boardman37
Aug 22, 2007 12:27 PM
Dainos
Mar 9, 2007 03:36 PM
