Under $700 S60 2.5T performance mods
Hey guys I'm new to this forum but I have had my 2008 S60 2.5T for a couple of years now. Let me give you some background, I am a 17 year old high school kid looking for under the hood modifications. I don't want to be a ricer and love the way my car looks on the outside. But that being said I do want to change some things. My price range is around $700 and I am looking for performance parts (not ecu upgrade) that will make my car sound/accelerate/or handle better. Any particular parts to help make my 45,000 mile car better? Remember I'm 17, have little car experience, and have a $700 or so price range. Any thoughts on what to do?
Thanks
Thanks
Very worth it if you like to own the corners! You will never plow through another corner or any of the round-a-bout's that are popping up all over the place.
I say all this having iPd's 25mm Track Spec Sways in both my R's and had there rear sway in my old S40 T5.
To use the rest of your money, I'd lower the car. Doing that will make the car look A LOT better and will make the sways shine even more.
If you want some more go, the tune is really the best thing to do. I know you said "not ecu upgrade", but just had to state it. Exhausts will be out of your budget unless you get one fabbed up for you. You can always get the center resonator cut out and replaced with a straight pipe. It will slightly increase to sound of your exhaust, as well as make it sound a little meaner. Should only cost $40 to $60 at an exhaust shop. Google search "JRL mod"
So if I were you, I'd do the sways, springs and Resonator delete.
You'd have buttons on your console above your CD player that say sport and comfort. I just can't remember if the 2.5T's came with that option or not. If you don't have that then it's no worries. If you do, you'd have to get a SUM calibration from the Volvo dealer. Pretty cheap but still another thing to know about.
Okay thanks for your help guys, oh and what is stage 0 exactly? I have had a new oil pump and filter installed and an oil change a month ago. Is there anything else that I should do before adding mods? I mean the car only has 45,000 miles so the tranny fluid and plugs should be fine right?
More Stage 0 stuff...
New PCV
New plugs anyways
Plug wires
Transmission flush
Vacuum lines
New filters all the way around
It's pretty much making sure your car is in the best shape as possible to be able to handle the mods you want to throw at it. Your car only being a few years old, and you not really tuning it for a more substantial increase in power (ie.. ECU, Down pipe, exhaust Ect...) i wouldn't worry about it too much at this point. But keep it on your to do list in the next year or two.
New PCV
New plugs anyways
Plug wires
Transmission flush
Vacuum lines
#18
#19
Here's an article for what you can use for fluid, so you may be able to go the auto parts store, but I recommend IPD, since they have a case of fluid. http://turbobil.com/SMF/index.php/topic,32.0.html
And here's a DIY so you can judge how hard it is for yourself:
http://www.ipdusa.com/uploads/sku_files/7945_INST.PDF
