Using oil s60
![Question](https://volvoforums.com/forum/images/icons/icon5.gif)
Hey everyone, I need some input on where and what to do next. My 2014 S60 is using oil. It has less than 5K since change and oil level is down to the last "XX's" on dipstick. Local dealer is "monitoring" it and they do not seem to concerned and say this is normal and think they are full of it. Has anyone else been thru this. Car has 63K on it.
This has come up a lot on the newer vehicles. Yes, it is normal given the number of miles that you are suggesting. My own opinion of this phenomenon is that with electronic monitoring systems, it might "seem" that the car uses oil more than a prior Volvo, but the fact is that your prior Volvo didn't have a low oil warning message.
If you are down about a quart in 2500 miles, then that's about what I would expect. If you are down a quart before then, that's high consumption.
I have also noticed that the newer vehicles are very sensitive to what they call a "low oil level". I had the message come up in an S80 with the 3.2 L and I ended up adding about 1/2 quart. I believe that they have adjusted the software to allow for more deviation before the low oil message comes up.
At any rate, this is a balance. On an older model that someone didn't check the oil, I've seen those cars 3 quarts low, or more, and no warning. Now, like low tire pressure, the situation is monitored and you are aware of it.
At least you have a dipstick! While oil level monitors may be appealing to those who do not check the oil level at every fill-up (should they be driving?) the electronic monitor only is perhaps my biggest peeve with my 2015 - second in line is the stupid can of goo + air pump instead of even a temporary spare. I've only had two flats in the last 25 years but both have been blow-outs where the goop + pump would have been useless.
Nate - I urge you to read this thread. Please take the advice of a guy who had to replace his engine on his own dime!
https://volvoforums.com/forum/search...archid=2631421
Jeff
Jeff
Nate, I'm not sure what your concern is - ie the fact that the car requires adds between changes or that you don't trust the electronic dipstick? Assuming the concern is you need to add oil between changes, consider the fact that new engines run thinner synthetic oil compared to years back (to reduce friction) and are designed around tighter tolerances out of the factory so for the most part car owners come to expect longer duration between fills/changes. If the car is using more oil than expected, then you should inspect for any signs of leaks (ie driveway spotting etc). Consuming oil over a longer term (say 2500 miles/quart) means the oil needs to go somewhere - usually the rings or valve seals. To say you can go 5000 miles before adding a quart suggests the engine has normal wear at 70K miles. Also note that this may vary with driving style - do you run the car hard before its fully warmed up? do you regularly hit the upper RPMs (ie getting onto the freeway etc)?
So you are saying you need to add a quart every 3000-4000 miles? I think the problem is one of expectations whether a car should be able to go the entire extended service interval without adding oil and what is considered normal or acceptable. Certainly adding a quart between changes is a hassle but I would not say that getting pistons/rings replaced or valve seals replaced is an appropriate response or even if doing so will up the interval to 7500 miles. If you have a dipstick, you should check it regularly - say every 3rd fill up. I always keep a spare quart in all my cars (buy cheap at Costco/Walmart) just in case.
