Low Oil
Old Jul 31, 2008 | 10:15 PM
Keith Tobberman's Avatar
Default Low Oil
How many of you have an 850 that uses oil?
There is another question below.
-Thanks
Old Jul 31, 2008 | 10:24 PM
Default RE: Low Oil
How low can the oil before causing engine damage?
Old Aug 1, 2008 | 04:40 AM
ShaginWagon's Avatar
Default RE: Low Oil
176,000k, no oil usage here.
no idea about level sorry.
personally I wouldn't let it get below the 'low' mark at any time.
Old Aug 1, 2008 | 09:00 AM
Psaboic's Avatar
Default RE: Low Oil
190K on ours and it uses "maybe" a half quart every 5000 miles.
Old Aug 1, 2008 | 06:00 PM
Default RE: Low Oil
110K and I use about 1/2 quart every 3K
Old Aug 1, 2008 | 11:08 PM
Default RE: Low Oil
Thanks for the replies. Does anyone know how much the oil would have to be down generally to damge the engine?
-Thanks
Old Aug 2, 2008 | 06:27 AM
Default RE: Low Oil
Usually down about 2 to 3 quarts. I had a car yesterday that only had 1 quart in it and all was still fine.
Old Aug 2, 2008 | 01:34 PM
wheelsup's Avatar
Default RE: Low Oil
I once drove from FL to NM (2400 miles or so) with almost no oil because the jiffy lube place cross threaded the oil plug. I brought it to a place in NM and they said it had about a quart left.
That being said, the manual I have for my 850 2.4L says to add oil when it gets to the "min" mark, which apparently is 1 quart low.
Old Aug 3, 2008 | 08:50 PM
bitter356's Avatar
Default RE: Low Oil
318k,I refill about 1/2 to 1 qt every 3k depending on how hard I drive it. The lifters clacking give fair warning in most cases.The sump pickup is close to the pan. As Tech has stated, I too have seen 1-2 qt in without problems.
Old Aug 5, 2008 | 05:36 AM
lister99's Avatar
Default RE: Low Oil
My girlfriends took 4 quarts the other day ..........she's such a dipstick
Old Aug 5, 2008 | 10:12 AM
Default RE: Low Oil
Thanks for all the replies. I am not sure exactly how much mine uses, but I was just worried because it went low enough that it took a quart just to be able to see the oil on the level.
-Thanks
brettboze
Mar 26, 2012 06:25 PM
wayne73
Aug 17, 2008 09:43 AM
glull
Jul 17, 2008 10:51 PM
elderzap
Nov 7, 2007 04:58 PM
