Voltage regulator?
Hello, I have been experiencing quite a few electrical problems that all started happening at once. I read that it may be a voltage regulator. I can only find one voltage regulator online
https://www.fcpeuro.com/products/vol...-bosch-8637851
But could it also be the voltage regulator on the DIM or does that only supply the electronics of the DIM?
List of problems:
1) Radio changes stations by itself, and volume **** does not work well (Doesn't matter what direction you turn it, it will either go really loud or slowly off)
2) Blower fan would stay on when car is off and would not wanna kick on at times when turning on ac (unplugging and plugging in the fuse seemed to work for a while...)
3) DIM module would turn off with vibration (I had that fixed for a little bit but the severe vibrations from the control arm had ruined my solder joints)
as seen in my DIM DIY repair guide
I am not too familiar with the Volvo electronics system as of yet. So I do not know the layout of how everything works as of yet. I can get an idea of looking where particular chips attach to, But that's about it.
List of problems:
From my knowlege there are 2 regulators. one that will drive particular electronics, and another that drives the DIM. I have read that the electronics are networked so that one is unpluged all others shut down. (when I unplug the DIM the alarm system, radio, lighting, AC, and starter no longer function.)
what year is your S60? The part you show is the main voltage regulator for the alternator - its job is to keep the output of the alternator to a steady DC voltage. There's some vids on Youtube for how to use a VOM to test - start by measuring the battery volts (car off) - should be 12.6V DC or so. Start the car. the voltage should go up to 14.5 or so. Load up the alternator by turning on the blower, rear defroster, high beams etc. Voltage should remain in the 13.x range. Now in terms of finding the "second" voltage regulator - you can either browse through the wiring diagram (volvowiringdiagrams.com ) - or if you think the issue is in the DIM, it does have a voltage regulator (search for L4925N ) assuming your car is like a 2003 or so. DIM problems can be in the cables, relay or the CEM (central electronic module is the part where Volvo hid a bunch of relays and switches as a unit). Note if you try to replace the CEM it may be mated to the immobilizer program so read up on that as well.
Originally Posted by ES6T
The term voltage regulator commonly refers to the one on the alternator. Modules have means to regulator voltage for network communication or a 5V reference for sensors, but those parts are not available from Volvo.
More than likely, you have three separate issues here.
I can rebuild the DIM myself; All it is is figuring out what parts are bad and replacing them. If it is the voltage regulator I can take the part number off of it and look on digikey (Or ask my work if they have an extra)
Anybody know what the part number is for that voltage regulator on the DIM? And if anybody can find a schematic for the DIM on a 2002 s60 than that would be extremely helpful.
while I am replacing the voltage regulator I am going to reflow the chips using liquid flux instead of the nasty paste flux.
as posted by mt6127 L4925N is the voltage regulator on board. I could not find its specific datasheet but I did find its brothers the L4925.
http://www.digikey.com/product-detai...3911-ND/715829
Out of stock on digikey
![Frown](https://volvoforums.com/forum/images/smilies/frown.gif)
I will have to check the Obsolete pile at my workplace for one.
Business_Socks
02-02-2009 05:50 PM
