Volvo s60 2008 p2 - Head and Timing - what else?
Old Feb 25, 2022 | 06:03 PM
imacoolnavyvet's Avatar
Default Volvo s60 2008 p2 - Head and Timing - what else?
I've got a 2008 car i bought for 1500, I have the head removed from the block, the timing belt, water pump, thermostat, pcv system, are all slated for change. What else should I do while i'm in here? Starter? anything with the turbo?
Old Feb 28, 2022 | 06:44 AM
Dingus1's Avatar
I would replace vacuum hoses that may be brittle and make sure all pulleys and tensioners are replaced with both your belts. Inspect cam seals for leaks. If your starter works, I would leave it, you can also replace them without removing the intake. New gaskets wherever you separated the two mating surfaces.
Old Feb 28, 2022 | 11:06 PM
That's my plan for it so far. What about the oil pump crankcase seal? should I do that while i'm taking things apart?
Old Mar 1, 2022 | 09:18 AM
Dingus1's Avatar
If it aint broke, dont fix it. Thats my motto
Martin R Ekstrom
Volvo C30
Dec 16, 2019 10:59 AM
johnl316
Oct 24, 2017 06:22 PM
Fa310tx
Apr 16, 2017 09:08 PM
bryans1
Jul 6, 2014 08:26 AM
alixsaintil
Aug 2, 2012 12:17 PM
