Where is Cyl #2?
Old Apr 29, 2009 | 10:09 PM
redz1006's Avatar
Default Where is Cyl #2?
CEL went on and when Autozone pulled the codes, got P0302 (Cyl 2 misfire).
I changed all my plugs a few weeks back with BOSCH Platinum+. Anyway, just wanted to know where Cyl #2 is. Based on haynes manual for 850, the cyl goes from 1 - 5 starting from timing belt side. I',m assuming same setup for S60.
Also just upgraded to EST Short Ram Intake . Coincidence or there is a connection ?
Car idles fine and drives fine. I guess once in a while (barely noticeable) it misfires and the computer flags it and turns on CEL. The messages window does not say Stop Immediately or some other message that would indicate Stop Driving. So I guess it is safe to drive the car in this condition. Is this a correct assumption ?
Will check plug, coil and injectors and see if it clears code permanently.
Thanks.
Old Apr 30, 2009 | 06:44 PM
Yes it is the same as the 850.
I would have to say maybe the coil is going bad. It would have nothing to do with the intake.
Old May 1, 2009 | 09:02 AM
redz1006's Avatar
replaced plug and inspected coil.
So far no misfires detected by OBD scanner for a couple of engine cycles.
Cannot really take the car out on the road yet as my whole front bumper is down. Fog light installation and front lip spoiler installion on-going.
Old May 1, 2009 | 02:12 PM
malaka's Avatar
Inspected the coil? How? You didn't fire it up and stick your tongue on it, did you?
A trick to see if coil #2 is bad is to switch it with, for example, coil #3. If #3 starts misfiring, then the coil is probably the culprit; especially if #2 fires just fine. If #2 keeps misfiring, I'd first suspect the cheapest -- ignition wiring to #2. Since you've already popped the top to do this, I'd do a compression check just for the heck of it.
I was going to answer the question of your thread by "under the hood, between #1 and #3" but figured that wouldn't really help.
Old May 1, 2009 | 11:02 PM
redz1006's Avatar
Just did a visual inspection looking for corrosion loose wires etc. Anyway first step is to replace plug. If the misfire is still there then my next step would be to swap coils and see if the other cylinder will misfire. I do not think this s60 has individual ignition wires.
So far so good as OBD still does not show any recorded misfires.
jmalkames
Mar 10, 2007 06:02 AM
notny41
Feb 28, 2007 08:58 PM
c70girl
Dec 5, 2006 01:55 PM
850_Wagon
Penta
Nov 28, 2006 04:44 AM
pisque
May 19, 2006 11:31 PM
