White Smoke
RE: White Smoke
Welcome to the forum.
Generally, white smoke from the tail pipe is either normal water vapour or coolant entry into the combustion chamber. The latter can be tested by doing a compression test, cooling system pressure test, etc...
As for the tranny, until you can get software upgrade, visit a local AutoZone or other auto parts shops that provide fee OBD-II diagnosis service and pull codes from the transmission ECU. The scanner used at AutoZone may not be able to access the tranny ECU but doesn't hurt to try.
Wait to see what other members think.
Wish you luck,
JPN
Wish you luck,
JPN
