wiring harness
Old Sep 9, 2007 | 09:02 AM
aqus's Avatar
Default wiring harness
Hi I just got a 2004 S60(very excited). I want to change the sound system since it comes with a HU613. I noticed that on the wiring harness it has front and back speaker wires but my car has 6. front doors, rear doors, and back panel. How do i connect? And if I decide to put a 4 channel amp can I just put it under the passenger seat, since the bigger systems come with an amp and installed there, does all the wiring connections go through there even though this vehicle came with a hu613? Again how would I connect 6 speakers to 4 channel amp? Or do I need another 2 channel amp?
TIA
Old Sep 9, 2007 | 09:44 AM
Default RE: wiring harness
If you go aftermarket first thing you will need to do is go to the Dealer and have them download software to remove the factory radio as a module in the network.
Then you can mess with the rest from there.
I would try with the 4 channel amp first and see how it sounds.
Check with crutchfeild and see if they make the plug kits to go from aftermarket radio to factory wiring yet.
Old Sep 9, 2007 | 11:13 AM
aqus's Avatar
are you serious I have to go to the dealer and pay to remove the original radio!!! Why can't I just unplug it?
Old Sep 9, 2007 | 12:44 PM
jks2's Avatar
The computer stores the radio. If you replace it the computer still looks for the factory radio and you'll get misreads and errors.
Old Sep 10, 2007 | 05:31 PM
Exactly the radio is part of the talking network of the car.
If you remove it the network is broke and signals are missing from places they should be.
Old Sep 14, 2007 | 12:12 PM
calas60's Avatar
What about if you are just trying to add an amp? I have a 1300 watt amp that I wanted to add.. is there a remote wire that comes from the radio?
Old Sep 15, 2007 | 08:21 AM
ORIGINAL: calas60
Not that I am aware of.
The Antenna is on one of the windows and has an Antenna Amp for the signal.
Old Sep 15, 2007 | 10:58 AM
aqus's Avatar
Ok I braught the car to the dealer before installation and they told me there is nothing to do on software upgrade unless I change with another radio. I guess I will remove the old and see what happens.
Also I have component speakers in front doors, speakers on back doors and on back deck. Anybody know what kind of speakers are in there. I want to a local audio shop and I told them I want to add a 4 channel amp giving 50Wx4 RMS http://www.pioneerelectronics.com/pn...829696,00.html and wanted to change the speakers also because they distort. He said that the speakers are good and there is no need to change them, it is the headunit amp which is distorting. Any experiences on adding an amp to these speakers? Can they take the power? The installer also said that removing the door panels is a PITA, and therefore says better left alone. I do already have a good pair of Alpine component speakers lying around, so I am hesitating. All I can see ids the back speakers says 8 ohm and no other info. I guess they are connecting in series with back door speakers to bring it to 4 ohms.
TIA
Old Sep 15, 2007 | 11:08 AM
If you are adding an aftermarket headunit software should be installed.
The guy you spoke to at the Dealer must not know his A** from a hole in the ground.
If you want I can get you the Part # and then you can have them download it.
It will cost you about $30.00 for the Software and .5 labor to have it done.
Old Sep 15, 2007 | 01:56 PM
aqus's Avatar
I would appreciate the part number. Luckily I spoke to the manager hehe. BTW is there a way we can do software upgrades ourself. I noticed besides putting gas in this car everything else seems to need a visit to tyhe dealer for a software download.???
TIA
Old Sep 15, 2007 | 03:03 PM
No way to do it your self.
8633566 is the part# to remove the radio function from the car.
Old Sep 25, 2007 | 06:14 AM
aqus's Avatar
Hi just to let you know that I removed the HU613 and installed an aftermarket system and everything works fine without the need of any download...
TIA
Old Oct 23, 2007 | 03:18 AM
arcanemirage's Avatar
Well I have the factory stereo with the 4 disc changer. I installed the ipod adapter and now my AM signal sucks. I took out the power and ground wires for the adapter but no dice. Any suggestions? Which window has the antenna on it? Maybe it has a problem. Thanks![]
sdl92
Jun 22, 2013 07:19 PM
sherry
Apr 13, 2006 06:15 PM
Zarkoff500
Oct 28, 2005 09:38 PM
AmishRebel
Jun 14, 2005 10:02 PM
AmishRebel
May 31, 2005 09:03 PM
