00 S70 wheel fitment
is anyone out there running 17x7 +45 wheels and having rubbing issue? i found the wheels i want for my s70 and those are the specs of the wheels. just want to make sure i don't run into any rubbing issues with it being lowered around 1.5". the tires will be 205/40/17. thanks
I run 16x7 for my snows, 49mm offset if I have it right. I use 5mm spacers all around. I'm lowered too and don't have any issues. 43 is factory on these cars. As you get closer to 49, it pushes the inner side in closer, hence why I have the spacers. You could for sure add 5mm spacers and be 100% fine. you could play with this too:
Wheel Offset Calculator
