1998 S70 GT FPR Access Location
Old Apr 12, 2022 | 05:46 PM
benjaminmaltieri@gmail.com's Avatar
Default 1998 S70 GT FPR Access Location
Hi I don’t actually own a Volvo I drive a Viggen, however I’m doing work on a 98 S70 GT and I just want to know where is the access location for the FPR? Through the right rear wheel well or is there an access cap under the right rear seat?
Old Apr 13, 2022 | 08:51 AM
Psaboic's Avatar
Hi if by FPR you mean the fuel pump relay, it is under the fuse box in the engine bay. If you look on the right side of the car as you are facing it, you will see the fuse box near the base of the windshield. You have to remove the plastic covering by the fuse box (4 torx screws T20 if I remember correctly) under that you will find the relays. Hope that helps.
Old Apr 22, 2022 | 07:47 AM
Psaboic's Avatar
If you mean the fuel pressure regulator, it is on the left side of the fuel rail as you are looking at the engine.
Old Apr 22, 2022 | 12:12 PM
firebirdparts's Avatar
Mine is under the engine. That is right around the right rear subframe bolt. That's on a 1998 T5. I don't know what a GT is.
dronejunkee
Feb 8, 2017 05:26 PM
Robitzski
Nov 17, 2015 08:03 AM
beamer68
Sep 5, 2015 12:51 PM
beamer68
Sep 3, 2015 07:53 AM
somebrains
Aug 26, 2013 07:52 PM
