1998 s70 short
Old Jul 10, 2020 | 11:19 AM
Poorasdirt69's Avatar
Default 1998 s70 short
Battery gets drained from radio amp and courtesy lights. Pull fuses and all is good.Where are these switches?
Old Jul 10, 2020 | 11:49 AM
radio amps are usually fed via a lead from the back of the head unit. Assuming you have the radio code for the head unit, try sliding it out and disconnecting the big connector to see if that drops the power consumption. Courtesy lights as in glove box/vanity mirror etc or do you mean the running lights?
Old Jul 11, 2020 | 01:47 PM
The lights in the door jams stay on. I think I figured out a cheap way to fix it by putting a spade terminal in each side of the fuse box and use a fused toggle switch on the dash to turn them on/off as needed instead of removing the fuses.
Old Jul 12, 2020 | 06:51 PM
or clean/replace the button switches?
Poorasdirt69
May 25, 2020 09:51 AM
PMOURASSA
Jan 3, 2017 05:28 PM
DoggyB22
Jan 27, 2016 07:00 PM
beachbumtroy
Nov 19, 2012 08:25 PM
mourassa
Sep 24, 2011 08:15 AM
