1998 S70 Volvo Serpentine Belt Replacement
Old Apr 17, 2009 | 07:52 PM
lmchle's Avatar
Default 1998 S70 Volvo Serpentine Belt Replacement
Can someone please tell me what size socket wrench would I use to fit inside of the pulley to push the tensioner forward? I'm not using the Serpentine Tool wrench, wanted to use socket wrench of my own. Please Help!!!!!
Old Apr 17, 2009 | 08:54 PM
BlazeS70's Avatar
I don't remember the size I used...but I would suggest getting an automatic tensioner so that you will never have to adjust it yourself again.
Old Apr 18, 2009 | 07:17 AM
The 98 does not have a nut you can use. What I have done in the past when I did not have the tool was slide a prybar between the pulley and bracket and move the tensioner.
Old Apr 18, 2009 | 09:35 AM
lmchle's Avatar
Okay, I'm confused. I'm a female trying to repair this myself. Are you saying I need to replace my old Tensioner?
Old Apr 18, 2009 | 09:38 AM
lmchle's Avatar
Tech when you say use a prybar, "Are you talking about a crowbar?" So what I need to do is stick the bar between the pulley that the belt have to thread thru and raise it so i can get the belt on. remember the space is very tight there. Do a 14 mm socket wrench sound about right? Do I need someone else to help me or can I do this by myself?
Old Apr 18, 2009 | 10:29 AM
The 98 should not have the 14MM on the tensioner. It should have a square slot that a 3/4 drive would actually fit into to move the tensioner.
If you have the 14MM then you should be able to use a 14MM wrench to move the tensioner.
Greengary
Oct 27, 2013 08:14 PM
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
shahidocean
Sep 14, 2010 06:45 PM
iscwebe
Feb 9, 2010 12:50 AM
