1998 Volvo s70 ABS and Service Light
Old Oct 31, 2010 | 11:16 PM
Stinger357's Avatar
Default 1998 Volvo s70 ABS and Service Light
Hi all,
Just bought a 1998 Volvo S70 from a dealer. And the service light comes on and off intermitently while driving. Also when I accelerated 1 day the ABS light came on and won't go off now. Any idea what might be the issue. I am going to take it to autozone to read the codes and report back here.
Thanks,
Old Oct 31, 2010 | 11:24 PM
alecw81's Avatar
Service light has to be reset at the dealer or with a special tool. It basically just means it's been 3000+ miles since the light was reset.
As for the ABS light, it seems that most frequently it means your ABS control module is going bad. There's a rebuild service that is far cheaper than buying a new unit, and apparently the rebuilds are actually better than the "new" Volvo units that have a flaw.
The ABS light COULD just mean you need to add fluid, but it's most likely the module.
Old Nov 1, 2010 | 09:47 AM
ddrewyor's Avatar
I have a 1999 V70 and when the module started going bad the lights on the dash would come on intermittently and with increasing frequency. It was not limited to the ABS light - the traction and others would come on. I had it rebuilt by this place and it has been working for over 2 years flawlessly. It has a 5 year warranty. Removal was fairly easy, you just need to get a 4.5 or 4mm torx. It tells you in the instructions.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Dave
________
AVANDIA CLASS ACTION
Old Nov 1, 2010 | 08:16 PM
S70_Driver's Avatar
As others said, likely the ABS module. When mine went, the TRACS light came on too. Get a rebuilt unit from an aftermarket supplier they recommend here. It's not that hard to swap.
Old Nov 1, 2010 | 09:10 PM
Stinger357's Avatar
Well I had my codes checked from a friend with a code reader. And the only code to pop up was a P0442 code. He then cleared the service light, but when driving it after that the light came back on, he checked it again with 0 codes showing. So I don't know why the service engine light keeps coming on and then off once I drive a little bit? Any idea and what the P0442 code was?
Old Nov 3, 2010 | 03:03 PM
Stinger357's Avatar
Can anyone tell me what a P0442 code is on a 1998 volvo s70?
Old Nov 4, 2010 | 09:51 AM
alecw81's Avatar
The Service light is NOT the Check Engine Light, and it can only be reset with a Proprietary Volvo Tool. You can't just use a Scantron OBDII reader.
Old Nov 5, 2010 | 08:20 AM
AudiDefector's Avatar
Dave
If I remember correctly, my S70 was a E5 External Torx. Some people might run out and get a Torx driver. It is actually an External socket, and it can be hard to find. I found mine at Advance Auto, but had to buy a complete kit of External Torx sockets.
Also, the heads of the bolts corrode and strip out VERY easily. Mine was "pre-stripped" for my convenience. I ended up cutting the head off of one of them with a Dremel and simply replacing the bolt\screw from one of my parts cars.
There is a guy on Ebay that sells them rebuilt for $69.95 shipped to your door. He allows you to send the core back on the honor system once you completed the job. His modules are very clean and always work great. Wish I hadn't waited so long to replace mine. I drove around for a year staring at both the ABS and TRACS light.
Make sure you buy the right unit, as they are different for TRACS and non-TRACS vehicles.
Old Nov 6, 2010 | 08:47 AM
ddrewyor's Avatar
Yep, you are correct. I looked at my socket and it is a E5 Torx. It had been a couple of years and I took a guess - I knew it was a hard to find size. I found mine at NAPA.
Dave
________
NEXIUM CLASSACTION
Old Nov 6, 2010 | 04:48 PM
S70_Driver's Avatar
When the ABS module goes out, you've still got brakes, but you've got no functioning ABS control anymore. It's a common thing in these older S70s - fortunately, a number of shops specialize in rebuilding them, which isn't too expensive.
Old Nov 8, 2010 | 07:33 AM
Stinger357's Avatar
well some good news...went to volvo and they reset the service light and all is good now. Expcept the bulb light keeps flashing so quickly when I step on the breaks prob a loose connection. Also ABS came back on and then off again, I will get the module looked at, thanks all that gave me advice,
Old Nov 8, 2010 | 02:10 PM
NauticSlowVo's Avatar
The ABS is an easy fix mosey on over to volvospeed.com and get in touch with MattyMoo as mentioned earlier he is the one that will send you a fixed unit and on the honor system you R&R yours and send him your faulty unit back. Mine cost me $55 shipped and is THE cheapest way to do this by far even IPD charges almost $300 for these same units. Good Luck.
http://volvospeed.com/vs_forum/index...580-matty-moo/
Old Feb 14, 2011 | 10:25 PM
Volky_one's Avatar
Yes replacing your ABS unit with a rebuilt one is far better than buying a brand new one, you can even drive your car without the module on, but, you got to be careful.
Old Feb 15, 2011 | 10:18 AM
I drove mine for a year with a dead ABS module. Never a problem. Even had a few hard braking scenarios, and it really didn't concern me. No problems at all. I finally bought a rebuilt module from Matt in Michigan, and it worked flawlessly and is still working after almost a year. I only fixed it, because I was tired of ABS and TRACS lights on the dash, and because I could do it for roughly $60.
I would never buy a $300 replacement unit. It defeats the purpose of having a nice, cost efficient, reliable Volvo, if you have to dump excessively priced parts into it.
Many of the module rebuilders are very good at what they do, especially seeing as this problem is generally caused by bad solder joints on the module power connectors. It is a simple fix for these guys. And, it will save you all hundreds.
Please respect the honor system and return your old modules to them so that they can help the next guy.
dawgcord
May 29, 2018 02:40 PM
nealeas
Mar 24, 2018 09:59 AM
claeslindgren
Jul 30, 2014 11:27 PM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
