1998 Volvo S70 power steering noise
Old Aug 31, 2009 | 08:31 AM
DPendergraft's Avatar
Default 1998 Volvo S70 power steering noise
I have a 1998 Volvo S70 that'sbeen well maintained. When I bought it 4 years old,there was minor noise during steering,almost unnoticeable. 7 years later, the noise increased significantly over the past few weeks and there's some difficulty in steering. The shop that's always worked on it here specializes in Volvos and has always done goodfair priced work. They looked at it and felt there was a leak in the power steering rack and that a re-built rack should be installed. They mentioned they could bleed the air out of the system and that should take care of the problem temporarily, but that it would comeback and driving it further could risk the pump,etc. My question is this...the power steering fluid level in the reservoir is normal. Is there a chance that a small amount of air has entered the system, but the steering rack is fine and bleeding air out is all that's needed? Not sure if it could be a factor, but we have rough brick streets in our town and I've had a fair amount of front end repair done, some within the past few months.Could the shop have inadvertantly allowed some air into the system during earlier repair? Hate to have to find $850 right now!
Old Aug 31, 2009 | 01:59 PM
fcpgroton's Avatar
Former Sponsor
I would have the system bleed first. If that fixes the problem, you are golden. If not, well, then you will need to put in a new rack. I would think the rack would start to make noise again before it would cause damage to anything else. I mean, you have been driving like this for 3 years now and the pump is still working.
Old Sep 1, 2009 | 12:32 PM
Thanks, we're goingto try that...fingers crossed!
Old Sep 4, 2009 | 06:58 PM
chrisg's Avatar
I don't know if its of any use to you but I had a bad noise from my power steering a year ago which turned out to be a bad leak in the steering rack. Lazily I opted for a bottle of Lucas Power Steering Fluid. Then a second bottle, and a week later no leak or noise and its been fine ever since.
rspi
Dec 28, 2011 08:43 PM
Rb_newsletter@yahoo.com
Apr 10, 2011 04:45 PM
shahidocean
Jan 15, 2011 08:51 PM
halekai
Oct 19, 2005 08:59 PM
Qamar
Aug 8, 2005 09:52 PM
