1999 s70 GLT turbo
Old Nov 22, 2015 | 10:00 PM
87blyota's Avatar
Default 1999 s70 GLT turbo
Howdy all, I'm not actually a Volvo owner but received a turbo off a 1999 s70 for free from a friend for a project of mine. Can anyone tell me which hole is the oil in/ out and the coolant in/out also what is the extra nipple on the housing for? this is the part I was given. 1999 Volvo S70 Turbocharger 2.4L Engine 40-30115 AN
Old Dec 1, 2015 | 06:23 PM
Volvos run Mitsubishi TD04HL turbos of various impeller sizes. Yours is likely a 16T (if from a S70T ) or a 13G (if from a S70 GLT (aka low pressure turbo). You should be able to research the TD04s on how they fit for project apps. If you have a 16T, you can sell it to an 850T owner looking for a nice upgrade if you decide not to do your project.
Old Dec 1, 2015 | 10:22 PM
87blyota's Avatar
Ok so the car it came off of was a "elt" but id assume he meant glt. thanks for all the information itll be perfect for what its going on.
Old Dec 11, 2015 | 07:33 PM
The oil and coolant lines are opposite on the CHRA. The hole that has the drain line (2 screw holes) is the oil drain, the opposite side is the oil inlet. If you have the compressor in your right hand and the turbine in your left hand, and the oil inlet on top, the coolant port closest to your body is the coolant return.
hsinchu
Mar 11, 2011 11:32 PM
rezology
Jun 13, 2010 10:42 PM
mitch603
Sep 30, 2008 06:44 PM
mitch603
Sep 30, 2008 06:18 AM
S70driver
Jan 29, 2006 09:10 PM
