2000 S70 AC problem
Old May 26, 2006 | 06:35 PM
waterkr1's Avatar
Default 2000 S70 AC problem
AC blows cold for approx. 20 minutes than gets warm. I have read other post and possible reasons:compressor bad, temp. gauge sensor, pressure cycling switch, cut out switch. Is the temp. reading of the outside air connected to the temp. gauge sensor? The temp readings sometimes is 110-140 when the real outside temp is 90-95. So, if the reading is 120, can the sensor cut off compressor? Were are the pressure cycling switch and cut out switch?
Thanks
S70VolvoDriver
May 26, 2013 04:01 PM
Palmetto
Apr 17, 2011 07:32 AM
rainman14624
Oct 4, 2010 11:49 AM
maines70
Feb 23, 2010 04:53 PM
waterkr1
May 30, 2006 11:05 PM
