2000 S70 Air Mix Control
Old Dec 29, 2007 | 10:57 AM
bendy918's Avatar
Default 2000 S70 Air Mix Control
I have a 2000 S70 and the air mix control doesn't appear to be functioning properly. Sometimes it doesn't turn, sometimes it turns freely but it never opens the vent. It is stuck in the closed position. I got a quote from the dealer and they said it would be about $400 for the part. They said that it can't be fixed and had to be replaced. Is there anything that I could try myself to fix it before having to get it replaced?
Thanks
Old Dec 29, 2007 | 12:04 PM
Default RE: 2000 S70 Air Mix Control
What exactly do you mean.
The air control for the vents is built into the center vents.
Old Dec 29, 2007 | 02:08 PM
Justin Mason's Avatar
do you have an aftermarket filter? sometimes this is triggered due to excess oiling.
Old Dec 29, 2007 | 04:08 PM
bendy918's Avatar
The **** on the far left which controls the outside air either jams and does not turn or turns and does not move anything.
Old Dec 29, 2007 | 04:09 PM
bendy918's Avatar
The **** on the far left of the vents which controls the outside air either jams and does not turn or turns and does not move anything. See image.
[IMG]local://upfiles/13062/27CBC736898345BFBDF2A704EE683BE3.jpg[/IMG]
Old Dec 29, 2007 | 04:14 PM
bendy918's Avatar
Here's the image. Sorry for the extra posts.
[IMG]local://upfiles/13062/087B73BA98324E05BCF4DDB999ED9210.jpg[/IMG]
Old Dec 29, 2007 | 04:34 PM
Behind the vents there is a rod that goes from the **** to a door in the dash.
I believe you can pop the center vents and check the rod.
Old Dec 30, 2007 | 06:07 AM
bendy918's Avatar
How do I take the center vents out?
Old Dec 30, 2007 | 07:40 AM
Use a hook tool and slide it into the vents and carefully pull the vents out.
garrisos101
Aug 7, 2011 04:34 PM
sporky
May 24, 2008 09:40 PM
Rustynuts
Feb 24, 2007 10:59 AM
gendy
Jul 17, 2006 02:22 PM
d1o2u3
May 24, 2005 01:02 AM
