2000 S70 Fog Lights
Old Aug 21, 2009 | 09:40 AM
BRATHAMAN's Avatar
Post 2000 S70 Fog Lights
I need help in installing my fog-lights. Should I remove the bumper to get to the holes for the upper brackets? What size bolts do I need
Old Aug 21, 2009 | 09:58 AM
Carrots's Avatar
Nope... you can get to them from underneath.
Old Aug 23, 2009 | 12:56 PM
BRATHAMAN's Avatar
could u help me install them? what size bolts would i need and how to get them in since the mounting is metal
Old Aug 23, 2009 | 07:44 PM
SOme self tappers should be fine.
Old Aug 23, 2009 | 09:20 PM
Carrots's Avatar
If you got a kit, disregard the following. If you just got the lights and switch from a salvage yard or something... you'll need to get some other parts- there's at least 1 relay under the dash that needs to be added, and you also need a main lighting relay from a car equipped with fog lights, otherwise, they won't work (learned about the main lighting relay being a different part from Tech when I added a pair to my own S70 a month or so ago )
Old Aug 24, 2009 | 01:35 PM
BRATHAMAN's Avatar
Wow thanks do u know where and which ones I need? Any part #'s
Old Aug 24, 2009 | 02:34 PM
Carrots's Avatar
Well, my car is a '98, so it's different from yours and I don't have the part #'s handy... but the needed relays are in the relay panel under the dash. Compare your panel to one from a car with fogs (either a '99 or a '00) and see what relays it has that yours doesn't. Then, the main lighting relay is in the fuse/ relay panel under the hood near the wipers- the one with lots of fuses, not the one labeled "Main Relays." You'll have to unscrew the cover and open it up, and the main lighting relay is the big long rectangular one. It's labeled "Main Lighting Relay," conveniently. Good Luck!
rspi
Jan 13, 2012 09:35 PM
Fly00
May 7, 2011 03:54 PM
GTO 06
Jan 28, 2011 07:59 PM
SpaceMomMort
Nov 6, 2008 02:02 AM
