Replaced Rack and Pinion, Power Steering Stopped Working
Old Aug 24, 2009 | 07:02 PM
vacuumboy's Avatar
Default Replaced Rack and Pinion, Power Steering Stopped Working
I have a 2000 S70 GLT SE, I replaced the rack and pinion with a used part maybe a couple of weeks ago because it was leaking. Yesterday, the power steering went out for like 20 miles or so and then it came back on. I am wondering if maybe the mechanic did not install it properly, or if this is an issue with a belt or the power steering pump or if I got a defective rack and pinion. Additionally, my car makes a noise that the mechanic says is likely an alternator but I have had no problems because of this as yet. Any info would be appreciated. Thanks
Old Aug 24, 2009 | 07:11 PM
Might be the pump or a bad rack.
What kind of noise is it?
Old Aug 25, 2009 | 02:42 AM
vacuumboy's Avatar
The noise was there before replacing the rack and pinion and has not changed. It sounds like a whirling noise similar to when a water pump is bad, but my mechanic said it is likely inside the alternator. What would make the power steering work intermittenly?
Old Aug 25, 2009 | 07:09 PM
The noise might be the Alt pulley.
The pump or a defective rack might make the steering stop working.
gshad37
Jun 26, 2013 09:50 AM
PHIL_V70_GLT
May 13, 2012 10:49 PM
big daddy russ
Jan 19, 2010 05:16 PM
holliday68
Oct 14, 2009 03:11 PM
bernielomo
Jun 5, 2006 09:16 PM
