2000 S70.... No transmission dipstick!
Old Oct 3, 2014 | 07:20 PM
JJJTX's Avatar
Default 2000 S70.... No transmission dipstick!
Is there any reason why one of these cars simply does NOT have a dipstick on the transmission? Rebuild?
The only thing I see is a little plastic nub that sticks up with a plastic cap on it.
Old Oct 3, 2014 | 11:10 PM
Vida's Avatar
There's a reason behind their madness. :P
Old Oct 4, 2014 | 05:12 AM
JJJTX's Avatar
So how do you add fluid or check it????
Old Oct 4, 2014 | 09:37 AM
ES6T's Avatar
There's a dipstick. Look under the lower radiator hose where it goes up over the transmission.
Old Nov 5, 2014 | 07:15 PM
Vida's Avatar
Old Nov 5, 2014 | 07:57 PM
Turk13's Avatar
Thumbs up
I agree, it's pretty easy to see on my car standing at the battery and looking down to the left. It may be easier to see if you remove the fresh air intake tube.
Old Nov 9, 2014 | 07:41 AM
Ralphy11's Avatar
Turk 13 is right on. That's what I have a 2000 S70. Pull the air tube and move the wire bundle underneath. Yellow in color.
Old Nov 10, 2014 | 06:24 AM
JJJTX's Avatar
Thats the issue. We did take it apart. Theres nothing but a little tube with a cap on it. No dipstick.
Old Nov 10, 2014 | 07:02 AM
gstallons's Avatar
Default dipstick
Some vehicles you will fill this to the edge or top of this hole ( with the car on a level surface , engine warm , idling in park ) w/the proper fluid until it just starts coming out .
Find out if this is the correct procedure .
Old Nov 10, 2014 | 12:39 PM
ES6T's Avatar
Well then someone broke it. It is equipped with a dipstick though.
Old Nov 10, 2014 | 09:23 PM
Turk13's Avatar
I would definitely order one then. Should be cheap online somewhere. On my car, the oil dipstick was broken, probably just made of cheap plastic and got brittle over time. I WOULD NOT SUGGEST what was posted above: filling it with trans fluid until it reaches the top??? Why, so you can drain it back out? lol
christian amezquita
Mar 10, 2015 06:48 PM
earthguy00
Feb 23, 2012 07:38 AM
nyvolvo
Dec 28, 2007 09:49 PM
tgkspike
Aug 22, 2007 11:28 AM
rfred
Sep 7, 2006 03:02 AM
