1997 960 transmission dipstick
Old Jun 21, 2007 | 11:21 AM
tgkspike's Avatar
Default 1997 960 transmission dipstick
Where is the transmission fluid dipstick? Also my service light just came on at 80,000. Is it a good idea to have it serviced by a volvo dealer?
Old Jun 21, 2007 | 08:42 PM
zmontgomery's Avatar
Default RE: 1997 960 transmission dipstick
On my 960 the transmission dipstick is on the driver's side of the engine between the throttle body and the firewall. It's down pretty low, and is yellow and square on top. If the light on is just the "SERVICE" light, you can turn it off by pulling out the little rubber plug on the bottom of your instument cluster (next to the trip odometer reset) and pushing the button behind it with anything that is small and pointy. According to the manual, the service light comes on every 10,000 miles just to remind you to change the oil.....which I find hard to believe. I change my oil every 3,000 miles. 10,000 is just way too long of an interval. Hope this helps.
Old Aug 22, 2007 | 11:28 AM
ppcgm's Avatar
actually ... Volvo says every 5k miles if you drive in the city or a dirty environment and 10k if you drive mostly highway under temperate conditions ... I change mine every 3-5 thousand too, depending on how long it's been and how much city driving ... oil is cheap, engines are expensive
arthur.porrello
Feb 15, 2013 12:02 PM
earthguy00
Feb 23, 2012 07:38 AM
EMS
Jul 21, 2009 07:08 PM
nyvolvo
Dec 28, 2007 09:49 PM
rfred
Sep 7, 2006 03:02 AM
