2000 s70 p0452 Code
Old Nov 18, 2012 | 08:29 PM
kwatt's Avatar
Default 2000 s70 p0452 Code
I had a P0455 or 453 (large evap leak), which I fixed. Long story short the hoses to and from the purge shut off valve were both seriously cracked. Both were replaced. I reset the code ant took the car for a test drive - 20 mile or so, no check engine light - i'm a happy camper
During the drive I stopped to fill the car up with gas. While filling I noticed gas trying to spill out of the fill tube but I could press the nozzle tight enough(rubber thing on it) so gas didn't keep spilling out. This happened just a few seconds after starting to fill the tank - I ended up adding something like 16 gallons.
This morning I went to fix a trunk switch issue and I moved the car and now the check engine light is on aqain. This time it's a code P0452.
Ideas?
Old Nov 19, 2012 | 09:05 PM
I would check more vacuum lines. Has the PCV been replaced recently?
Old Nov 20, 2012 | 08:57 PM
kwatt's Avatar
I'll keep checking. I haven't done anything with the PCV. Oddly, since I reset the check engine light *again*, the light has not come on.
Old Nov 25, 2012 | 08:51 PM
Lifesgoodhere's Avatar
check the valve under the drivers inner fender well. common leak point. Also. You have the evap box by the gas tank.
yes40
Jan 24, 2013 08:13 AM
anniqu
Nov 20, 2010 01:05 PM
rainman14624
Oct 4, 2010 11:49 AM
badmonkey
Jul 28, 2008 09:15 PM
gzh
Mar 21, 2007 09:29 PM
