2000 S70 Starting Problem
Old Feb 7, 2010 | 02:21 PM
maines70's Avatar
Default 2000 S70 Starting Problem
Having intermittent problem staring engine. Sometimes the engine will start and run for maybe 1 sec and then stop. We turn the key back to off position and try again. It may take several tries but then the engine eventually starts and stays running. Happens most times when the engine is cold but has happened at running temperature. Any suggestions?
Old Feb 7, 2010 | 11:51 PM
Maybe you have a fuel delivery problem. Could be an air flow meter as well. You may want to pull codes.
Old Feb 14, 2010 | 09:16 AM
s70_t5_1999's Avatar
this happened to me, usually on humid days. the car would start, run for a second or two, and then sputter and die out. there were a couple of air leaks where moisture was getting into the engine upon startup, replaced the hoses and the problem went away. check for air leaks?
Old Feb 23, 2010 | 04:53 PM
frestonia's Avatar
could also be the immobilizer antenna ring. try unplugging it and plugging it back in before replacing.
Krogger
Aug 27, 2013 10:40 AM
kennedy759
Jul 23, 2013 10:21 AM
nicoletta
Jul 23, 2013 10:20 AM
TobieRoodriguez
Apr 16, 2012 07:04 PM
sk799
Oct 17, 2005 09:16 PM
