98 v70 runs rich only on a full tank...
Old Nov 23, 2013 | 11:37 PM
SAVolvo98's Avatar
Default 98 v70 runs rich only on a full tank...
Some how (only when above a 2/3 tank of fuel) my car runs rich. First instinct i drop the tank to check the pressure relief valve on the top of the tank.. There was no such valve. Second i'm thinking the valve is on the charcoal canister. i have yet to find out where it is. If anyone knows what might cause this and or where the canister is, the help would be much appreciated.
also i have found that there are also 2 other possibilities. 1. A shut off valve for the charcoal canister inline before the canister. 2. that the valve is actually a part of the fuel pump in which case i would have to change the pump. again any ideas would be appreciated.
thanks
Old Nov 24, 2013 | 05:59 AM
kwatt's Avatar
Why are you thinking the car runs rich? Is it throwing a code? You have black smoke coming out the tail pipe? Mileage is bad? You just think so?
Old Nov 24, 2013 | 10:08 PM
SAVolvo98's Avatar
Mileage is bad, exhaust smells rich and is black but not very excessive, and runs rough. as an example it runs like a carbureted car would if your jets were to large. it is throwing 5 codes one of which is for the evap the rest all could be caused by that. things like random miss, system lean (oxygen sensor), ect. that is why i'm pointing the finger at the evap system. wouldn't be the first time i was wrong though.
Old Nov 24, 2013 | 10:29 PM
kwatt's Avatar
List the codes you pulled, not the system affected.
Old Nov 28, 2013 | 01:35 AM
gdog's Avatar
Like kwatt said, list your codes please.
You may need other stuff fixed too, but your symptoms point to EVAP system not functioning properly; most likely Evap valve stuck open.
act1292
Nov 11, 2009 10:24 AM
KIA
Jun 9, 2009 01:54 PM
1990TURBO740
Apr 9, 2009 06:06 PM
junkmorning
Apr 14, 2005 12:08 AM
