'99 S70 starts and run, but has no power
Old Nov 11, 2010 | 04:34 PM
Cire2105's Avatar
Default '99 S70 starts and run, but has no power
99 s70 GLT 2.4L non-turbo
The car starts just fine then the engine revs a little and then sounds like its gonna die but when put in drive i can put the peddle to the floor and i will not gain any speed?? any suggestions would that be an issue of using mid-grade gas as compared to premium??
Old Nov 11, 2010 | 09:13 PM
How long have you owned the car? Do you have a CEL? Has this problem been getting worse? Not enough information for anyone to help you.
These cars run GREAT on any grade gas.
Old Nov 12, 2010 | 06:19 AM
S70_Driver's Avatar
I always run 87 octane in my normally aspirated 1998 S70, no problems.
Old Nov 13, 2010 | 07:42 PM
Cire2105's Avatar
Only had the car for about a month, CEL? just got it registered a week ago and started drivein it, it ran fine sometimes then some times would have that problem, but now it seems to have gotten worse.
Im new to volvos.
Old Nov 13, 2010 | 11:24 PM
Stinger357's Avatar
I use 89 octane and it seems to run the car fine...91 would be better but who can afford 3 bucks a gallon!!!
Old Nov 14, 2010 | 06:07 AM
I run 93 all the time in all of my cars. I figured that I get better gas milage with it so that makes up the difference.
As for the NO POWER problem, CEL = Check Engine Light. It kinda sounds like your car may be in the "Limp Home" mode. If that's the case, you will have a cel. Until you get that checked and cleared the car will likely stay in Limp Home. If you do have a cel, you can go to AutoZone, O'Reiley's, etc. to have the codes pulled for free. Then post them back here.
Old Nov 15, 2010 | 06:50 PM
Cire2105's Avatar
P0036 was the code, downline O2 censor is what autozone told me.
Old Nov 15, 2010 | 08:29 PM
Cire2105's Avatar
correction p0036 (code) Heater Control Circuit (Bank 1 Sensor 2) from which i understand is the rear o2 sensor? and if so, where abouts is that located?
Old Nov 16, 2010 | 07:05 AM
I'm not sure about the code but the rear o2 sensor is just behind the catty on the exhaust. I have not heard of an o2 sensor effecting power though. You may want to wait for a pro to answer that, like tech, carrot, etc.
I did a search and found this link: https://volvoforums.com/forum/volvo-s70-33/i-need-help-guys-28702/
Old Nov 30, 2010 | 07:23 PM
Cire2105's Avatar
Replaced the O2 sensor and it ran good for 4 starts and no CEL then CEL came back on with the ETS light and back to the same problem, when it ran w/o the CEL on it runs perfect, but shut it off and it comes back on. also with the ETS light. i found this link for a recall, take a look at it and let me know if you think this could be the problem.
http://home.comcast.net/~donwillson/VEXED_won.html
Old Nov 14, 2011 | 12:06 PM
metropgh@hotmail.com's Avatar
My 99 Volvo s70 has no power when cold but when warms up runs great. Any ideas?
chucksrt
Oct 4, 2014 07:36 AM
RobieH
Jun 9, 2012 12:58 PM
dwaino@live.com
Aug 6, 2010 07:34 PM
mark_disfree
Dec 19, 2008 01:10 AM
