ABS Pump Motor Assembly - How difficult?
Old Aug 16, 2017 | 11:47 AM
pjbonthebeach's Avatar
Default ABS Pump Motor Assembly - How difficult?
2000 S70 non-turbo - Mechanic says ABS light code is a bad ABS Pump Motor Assembly. Replacement part is reasonable, but what is involved in replacing the beast. I cannot find any videos or instructions past replacing the module. There are obviously brake lines involved, but that should not slow me, a seasoned car guy, down too much. Thank you.
John, Cape Canaveral, FL
Old Aug 18, 2017 | 07:43 AM
Psaboic's Avatar
John, it is pretty straightforward, remove the module, all electrical connections and brake lines. Replace the motor, re-assemble, and bleed the brake lines throughly. Check matthewsvolvosite.com and you might find a DIY there as well.
shoeboxOH
Feb 26, 2017 12:34 PM
pmundo01
Dec 1, 2014 06:41 AM
turboxr
Dec 17, 2011 12:35 AM
mlabrut
Oct 16, 2011 10:47 PM
larry_s
May 15, 2011 04:24 PM
