abs sensor replacement
Old May 15, 2011 | 03:42 PM
Woodreno's Avatar
Default abs sensor replacement
How do I replace a rear ABS sensor on a s70 t5
Old May 15, 2011 | 04:10 PM
Carrots's Avatar
Not too hard to do. Unbolt the old sensor, unplug it, and replace. Easy, really. Just don't overtighten the bolt. But before you replace the sensor, I assume you're getting a code? The sensors themselves don't fail too often. What DOES happen is the sensor ring on the wheel hub gets packed with dirt and brake dust, which makes the sensor pick up an erratic signal. Before condemning the sensor, remove the rear rotors. See that toothed wheel that rides just below the sensor? Clean it with brake cleaner spray and a stiff nylon brush. Be careful not to hit the sensor and break it off. Also, clean the sensor itself the same way. Do this on both sides, and clear the ABS codes if necessary. See if this fixes it- I'll bet it will.
Old May 15, 2011 | 05:56 PM
tony1963's Avatar
Also, a bad ABS module will give false codes.
Old May 17, 2011 | 10:03 AM
twoarcadians-volvo's Avatar
Saw thread about resoldering bad ABS module. How is this done?
piv15
Nov 3, 2012 07:56 PM
sjbyy520
Jul 24, 2011 06:48 PM
J Dubb
Jun 25, 2011 08:11 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
