AC compressor constantly running!
Old Oct 25, 2008 | 08:28 PM
dwwhite's Avatar
Default AC compressor constantly running!
I just got my first Volvo, a 1998 S70.
After driving my first 50 miles, I began to hear a horrible noise under the hood. My dad, the mechanic, determined it was the AC compressor running constantly whether the AC switch was on or off. We have disconnected it to make it quite.
Any ideas on what is going on here?
Old Oct 26, 2008 | 08:08 AM
Default RE: AC compressor constantly running!
Did you have the defroster for the windshield on?
Old Nov 10, 2008 | 10:09 PM
dwwhite's Avatar
No the defroster is not on.
Old Nov 11, 2008 | 08:11 AM
If it was stuck on then either the relay went bad or the clutch seized up and was staying on.
Old Jun 20, 2009 | 01:50 PM
dwwhite's Avatar
tech: thanks for the reply. its getting warm and im trying to figure this one out again.
my mechanic (my dad) noticed the compressor isnt kicking on immediately but a few seconds after engine startup. i also just removed the relay and the compressor did turn off. do you have a wiring diagram on that relay so i can check to see if its good.
ive been leaving the compressor unplugged to keep down on the noise and prevent lockup.
also, we arent seeing the fan turn on when the system is turned on from the cabin.
Old Jun 21, 2009 | 09:09 AM
Open the relay and inspect it or swap it out with another one.
Also if the cooling fan is not coming on then the compressor should shut down once the high pressure gets to high.
missthe122
Feb 16, 2011 10:50 AM
luke8_8
Mar 28, 2009 02:27 PM
rgmendoza
Aug 28, 2008 10:46 PM
gagnecs
Jun 3, 2007 09:02 PM
ko_kidd
Aug 13, 2006 08:27 PM
